Author Topic: Anyone Use Something like this for Brake cutoff?  (Read 25142 times)
Offline Marlz
« on: December 12, 2016, 08:21:31 AM »
So this seems to be a basic magnetic sensor.
http://screencast.com/t/8Tqh8WlA
I'm curious if anyone has used one.  This sensor has a three wire configuration but the Magic Pie cutoff switch wire only has two wires (from what I've read)
Thoughts?
Re: Anyone Use Something like this for Brake cutoff?
« Reply #1 on: December 12, 2016, 12:29:49 PM »
The later Magic Pies and Smart Pies with the Vector controller have the three wire brake cable but only use the Black and Blue wires for the standard mechanical switch:
The Hall sensor type (as shown in your link) requires the additional +5V feed from the Red wire for the Hall sensor to work.
It should be possible to remove the cable and connector from the GM brake lever, and then solder it to the Hall sensor wires to allow it to plug into the Magic Pie's control Harness.
GM Canada sells the hydraulic brake systems with the Hall sensor integrated into the brake lever assembly:
They come already fitted with the correct connectors to plug straight into the GM control harness (as shown in the top photo).
« Last Edit: July 02, 2017, 11:56:57 AM by Bikemad »
