Author Topic: Magic Pie 5 Android app crashes depending on Android version  (Read 26505 times)
Offline Imnama
« on: September 22, 2016, 11:13:06 AM »
App version 1.32, may 2016
On my older Acer Liquid 700, with andriod v4.4.2 (KitKat), the app works without a problem.
On my newer Acer Liquid Zest Plus, with Android 6.0 (Marshmallow) the app crashes as described in other posts.
So my conclusion is that the app is not compatible with newer version of Android.
I would like to know which version of android anyone is using and if the app works or crashes
Re: Magic Pie 5 Android app crashes depending on Android version
« Reply #1 on: September 24, 2016, 10:45:04 PM »
I've used both App versions (Original v1.13 and later v1.32) successfully on Android v4.4.4 and (apart from an occasional hiccup with the Bluetooth connection) they both work fine.
Offline Tgice
« Reply #2 on: August 14, 2017, 10:29:56 PM »
Ugh, I'm having an app crash problem too, with version 1.32 on Android 7.0 on a Moto G5 Plus.  It just will not launch.  I even created a GoldenMotor folder off of the root (where I know from my older Moto X on Android 5.1 [which works] it will create the folder for data) and it still does not launch, keeps crashing.
Golden Motor, could you please investigate this and fix?
« Reply #3 on: August 14, 2017, 11:20:25 PM »
Have you tried any of the other versions that can be downloaded from this thread?
Offline Papagino
    • Colloidal silver, your immune system's best friend...
« Reply #4 on: September 20, 2017, 02:15:55 AM »
New Android Apps version 1.6 now available...
See this post:
https://goldenmotor.com/SMF/index.php?topic=6327.0
Cheers
Dan
« Reply #5 on: September 21, 2017, 08:45:24 PM »
Thanks for the update Dan, I have also added it to the thread I previously mentioned so that all of the Apps are in one place.
