Author Topic: Magic Pie Edge PAS wiring  (Read 23257 times)
Offline OldManTomahawk
« on: June 26, 2016, 10:10:43 PM »
Hey ,
PAS Wiring 'TheEdge'.  Gary told me to cut off the connector on the PAS and add wire a necessary to reach (TerraTrike Sportster) the sprocket as the motor is on the rear 26' wheel.  I need to confirm that the wire , I'll be connecting to is the 'pigtral' closest to the motor and the color of wires will be the same as on the PAS.  Gary said, the controller will work correctly when its connected.  I also have another 'pigtail' off the splitter that has 4 wires with connectors on the opposite end going to brakes, etc.  Any help will be appreciated"
Tom
Re: Magic Pie Edge PAS wiring
« Reply #1 on: June 26, 2016, 11:42:21 PM »
Hi Tom andto the forum.
The following diagram clearly shows the two sets of four wires you are asking about which should be exactly the same as the ones on your Magic Pie Edge harness:
The four core cable on the motor harness is for pedelec (PAS) and reverse functions, whereas the four core cable on the control harness supplies battery voltage to a suitable LED headlamp and horn via the light switch on the throttle unit and the horn button on the cruise/horn switch unit respectively.
The GM pedelec sensor usually has Red, Black and Green wires which connect to the Red, Black and Yellow wires on the motor harness:
   Red to Red
 Black to Black
Green to Yellow
If you wish to utilise the reverse function (which may be handy on a trike) you will need to wire a simple On/Off switch to the Black and Blue wires on the motor harness. Switching the Black and Blue wires together will activate the reverse function if it is enabled in the software. The maximum reverse speed can be set independently of the maximum forward speed so that it will go much slower in reverse.
« Last Edit: July 02, 2017, 04:28:22 PM by Bikemad »
