Author Topic: Magic Pie III wiring 'bullet' damaged, how to repair?  (Read 23329 times)
Offline Oldskoolboarder
« on: April 26, 2016, 03:57:13 PM »
I have a Magic Pie 3 20" wheel that we just started to use.  We're not sure exactly how it happened but appears that during one of the rides, the cable got caught along the axle and wound up. W/ all that torque, it pulled on the Golden Motor bullet connector and the wires ripped out.  I'm guessing it's the battery wires as it's only 2 wires that are red & black.
Pix attached.
What's the best way to fix this?  I can't see any way to open that plastic bullet connector to re-solder the power wires.  Short of cutting all the wires, removing/bypassing the bullet connecter and resoldering all of them back together, is there a more elegant fix?  I suppose I can disassemble the Magic Pie and replace that whole wire assembly but I can't seem to figure out where to get a new assembly.
I imagine I'm not the only one who's had this problem before so maybe somebody smarter than I has figured out a good way to fix it.
Thanks in advance.
Re: Magic Pie III wiring 'bullet' damaged, how to repair?
« Reply #1 on: April 26, 2016, 09:26:38 PM »
Looking at you photos, it is definitely the red and black battery wires that have been tugged out completely due to an insufficiently secured axle.  :(
I suspect the axle nuts may not have been done up tight enough to prevent the axle from spinning (the tabbed torque washers alone would be unable to withstand the maximum torque generated by the Magic Pies.)
I strongly advise fitting some additional torque arms to prevent the axle from spinning again after the wiring has been repaired and the wheel refitted.
I think that the molded multi-connector block (the one that the battery cable has been pulled out of) will contain a small circuit board where some of the wires are joined. (Check out this post for more wiring details.)
As the thick power wires have been pulled out completely, I suspect that the excessive force on the cable may also have torn away the tracks on the circuit board where they were originally soldered onto it.  :(
I suggest you very carefully cut open the molded body of the multijunction unit with a sharp modelling knife etc. to obtain access to the battery wires coming from the motor. Hopefully you will be able to resolder the detached battery cable directly to these wires to create an effective repair.
Apply some silicone sealant and then bind the joint with insulation tape or heat shrink tubing if the wiring repair is successful.
Unfortunately, it is impossible to say whether (or not) any of the other wires may have been damaged internally by the tremendous tension applied to the motor harness when the axle spun.
If the damaged connector cannot be repaired (or its connections bypassed completely) I don't think that a replacement motor harness can be purchased separately, so you may need to purchase a replacement controller instead that comes with the motor harness already attached.
Please keep us informed with the progress of this repair.
« Last Edit: July 02, 2017, 11:26:22 PM by Bikemad »
Offline NR
« Reply #2 on: April 27, 2016, 07:06:10 PM »
I have once cut open the moulded block on a smartpie, as it is only wires and a single component, think it was a ptc resistor which had a broken leg and no voltage went to control handle, so motor wouldnt run, there was no printed circuit, only wires, so no worries opening it, reconnect stripped wires and cover with shrinktube preferable with heatglue inside for better waterproofing.  8)
