Author Topic: Magic Pie 4 throttle stuck full speed  (Read 22383 times)
Offline Websitescenes
    • WebsiteScenes
« on: April 07, 2016, 06:11:51 PM »
Been enjoying my pie for about 6 months now without issue. Then the other day I pressed the thumb throttle and the bike lurched forward stuck on full speed. After a few seconds throttle control came back and I dismissed it as a fluke. Then it started to happen more frequently and now with even the slightest touch of the throttle, the bike is stuck in full speed and I have to kill it. I've replaced the front harness and the throttle with same results.
Is it possible cruise control is is stuck on? I don't have a cruise control switch or even know how to operate that feature.
Re: Magic Pie 4 throttle stuck full speed
« Reply #1 on: April 08, 2016, 10:59:25 AM »
It will definitely not be the cruise control sticking on as it cannot engage without the cruise button being pressed (and you don't have a button to press).
Check out this thread for a similar problem that was caused by water in the connectors.
Controllers can also be adversely affected if water enters into the controller housing:
Direct water cooling should always be avoided inside air cooled controllers.  ;)
« Last Edit: July 02, 2017, 04:26:38 PM by Bikemad »
