Author Topic: mm inside rim width?  (Read 28152 times)
Offline Guyblat
« on: December 03, 2015, 09:15:44 PM »
What is the inside RIM width in mm on a MP5 Vector 700c rear hub motor? I'm trying to buy an airless tire from this company and need the measurement for a good fit:
http://www.airlesstiresnow.com/Nu-Teck--Marvel-Compound-City-Tread-Airless-Tire--Options_p_253.html
Also, if you have it, what is the depth in mm?
*See image for illustration
Thanks! Guy
« Last Edit: December 04, 2015, 10:51:30 PM by Guyblat »
Re: mm inside rim width?
« Reply #1 on: December 04, 2015, 11:38:01 PM »
I have just measured my GM 700c rim and the inside rim width is 18.4mm and the depth at the outer edges is 6.8mm and more like 10 mm to the rim tape at the deepest point in the middle of the cross section.
Offline Guyblat
« Reply #2 on: December 04, 2015, 11:43:01 PM »
Thanks!
« Reply #3 on: December 05, 2015, 02:22:22 AM »
Out Side measurements are still the same as 2010 :)
http://goldenmotor.com/SMF/index.php?topic=2308.msg12759#msg12759
