Author Topic: HPC500H 96400 programming problem using PI-400 and HPCMIS_WIN.exe  (Read 26258 times)
Offline Pawel
Hi!
My name is Poul and few days ago I have started playing with 10kW BLDC motor from GM connected to HPC500H 96400.
I am having following problem:
When voltage on my battery increase above 90V engine stops and I am not bale to reach half of nominal RPM without the load.
I have connected controller to PC using PI-400 kit and using HPCMIS_WIN.exe application I was trying to change over voltage shutdown level from 90V
to 96V. Application reports no error, but after reading I see still 90V:(
What is wrong?
BTW: Monitor tab seems to work fine.
I am using 10kW motor from GM
Offline Pawel
Re: HPC500H 96400 programming problem using PI-400 and HPCMIS_WIN.exe
« Reply #1 on: October 19, 2016, 09:10:06 PM »
Problem has been solved.
Controllers had 72V logic inside 96V cover!!! :'(
« Reply #2 on: October 21, 2016, 09:46:55 AM »
Presumably it had the correct internal hardware but had somehow been flashed with the incorrect firmware?  ::)
Good to hear it is now sorted.
