Author Topic: Hooking up Magic Pie 4 controller  (Read 27213 times)
Offline Dangwillo
« on: October 07, 2015, 05:42:20 PM »
I took my controller off to attempt to fix broken wire.  How do I plug green, blue, and  yellow wires? †here are three terminals A B C. Thanks
Offline Dangwillo
Re: Hooking up Magic Pie 4 controller
« Reply #1 on: October 07, 2015, 06:15:05 PM »
Here is a pic of my controller.  I found an old thread with a different looking controller in which Alan listed 5 possible combinations. Just figured someone should know order.
Offline Dangwillo
« Reply #2 on: October 07, 2015, 08:04:23 PM »
Been sitting here all day searching internet and nothing. Frustrating that this info is not easily available>
Offline Dangwillo
« Reply #3 on: October 07, 2015, 09:12:19 PM »
Good news maybe.  I hooked the wires up one way, and a loud noise came out.  I tried another, and the wheel spun. I figure I fixed it. Put it back together, even with GM's stripped screws.  Then I tried it out, and the wheel went backwards.  So I figure it works, maybe. I just need to hook it up right. And I won't even try again until someone gives me a heads up.
Offline Zerogee
« Reply #4 on: October 07, 2015, 09:21:03 PM »
Offline Dangwillo
« Reply #5 on: October 07, 2015, 09:35:09 PM »
Yes it does.  Thanks very much.  I watched another video Alan had suggested and it had a different controller.  SO here I go, and thanks again!
Offline Dangwillo
« Reply #6 on: October 07, 2015, 10:34:40 PM »
I tried it and the motor still goes backward. :'( I have tried several combinations. and to make matters worse I am doing this with the bike upside down and the break disconnected, which was engaging the regen brake, preventing the wheel from working. SO I may have fixed it and not even known.  I am pretty frustrated and cannot understand why I cannot find any info on this.  I am going drinking, and if that don't work, well I got a hammer. ;)
« Last Edit: October 08, 2015, 12:00:43 AM by Dangwillo »
Offline Dangwillo
« Reply #7 on: October 08, 2015, 02:10:08 AM »
So I think I fixed it, but I twisted the throttle and the torque pulled the wheel out of the dropouts. But that's a good sign.  I went to hook the MP5 to another bike, but- I lost a part for the fork, the old kind.  ARRGH!  At least I learned something. :)
Offline Dangwillo
« Reply #8 on: October 08, 2015, 01:46:49 PM »
I am at a loss.  Now it works in spurts and the throttle will not shut off.  I think it is time for the hammer, becasue I am done with this crap
Offline Dangwillo
« Reply #9 on: October 08, 2015, 06:10:41 PM »
The hammer has not come out, but man has the frustration.  I put the MP on another bike, and erratic wattage, but no error codes on LCD display.  I really would like some information on how to wire the controller?  says mp 4 v 5 3.1
« Last Edit: October 08, 2015, 07:02:02 PM by Dangwillo »
« Reply #10 on: October 08, 2015, 11:42:10 PM »
Here are the connections on my original MP4 controller:
Unfortunately, your controller looks quite different, so there is no guarantee that the phase wires will be connected in the same order.
« Last Edit: July 02, 2017, 09:52:58 PM by Bikemad »
Offline Dangwillo
« Reply #11 on: October 10, 2015, 01:22:32 PM »
Kasen got back to me and sent me the phase wires for my controller. The combination was yellow, blue, green; A<B<C.  I'll see if I can attach the jpg he sent me.  Consequently, I hooked up the controller the correct way and it appears to work, but I had some strange pulsing phantom pulsing of the throttle at first when I pressed the mode button.  Seems to work okay, except that it maxes out wattage sometimes, and sometimes it doesn't.  I wonder if shorted out the pedal assist wires?
Anyway, I am glad to at least know that the controller works! I will update later and see how it goes.
« Last Edit: October 10, 2015, 01:31:07 PM by Dangwillo »
