Author Topic: VEC500 temperature settings  (Read 21817 times)
Offline Nuxland
« on: May 18, 2015, 04:42:39 PM »
Hey
Does anybody knows the meaning of motor temperature levels.
level 1 and level 2, what will happen when level is reached? These degrees are in celsius I think.
I assume that controller will reduce current but how much and etc.
I think that I have reched these levels because after 7 laps (1km lap) of racing current was automatically lowered from 250A to 220A and then to 200A.
When I stopped after 10 laps then motor outside temperature was only 40 degrees celsius. Motor is HPM-10kw 48V version.
I didn't know at the time that I could measure resistant between white and black cable from motor (connected to ground and temperature sensor inside).
Motor should have KTY84/130 inside and resistants should be 1,1kohm with 120 degrees of celsius.
