Author Topic: BAC-601 Error 9  (Read 28590 times)
Offline MrBubbles
BAC-601 Error 9
« on: April 25, 2015, 03:49:10 AM »
I just received my BAC-601 Smart LCD and have the same firmware(?) configuration as Lewis in this post: goldenmotor.com/SMF/index.php?topic=5572.msg31706#msg31706 - only 3 settings (SE) menu options.
Furthermore, my unit repeatedly generates Error 9 (Communication failure) and doesn't provide any information. Anyone have any suggestions or am I going to have to return it?
« Last Edit: April 25, 2015, 03:55:15 AM by MrBubbles »
Re: BAC-601 Error 9
« Reply #1 on: April 25, 2015, 10:54:35 PM »
I suggest you contact David at GM China and explain your problem and see what he suggests.
« Last Edit: July 05, 2017, 03:35:02 PM by Bikemad »
Offline Lewis Balentine
Re: BAC-601 Error 9
« Reply #2 on: April 26, 2015, 06:05:14 PM »
That is correct.
There is no longer a "fine adjustment" for the wheel size.
Offline MrBubbles
Re: BAC-601 Error 9
« Reply #3 on: May 16, 2015, 11:16:46 PM »
Thanks All.
I returned the Smart LCD to Gary at Golden Motor Canada and it tested fine at his end.
I'm wondering if the controller might be the problem - however, the USB Cable/Software works fine so I'm inclined to think the controller is fine as well.  The bike itself is also working well.
The only other thought is if there's a compatibility issue with different revisions of the MP4/Smart LCD - I've contacted David as suggested and am awaiting his response.
Offline Mikalow
Re: BAC-601 Error 9
« Reply #4 on: May 18, 2015, 03:37:37 AM »
could I get Confirmed
Have some input for the Magic Pie 4 and BAC-601 Smart LCD
I got one to work with the Smart Magic Pie 4 would not work
purchased a Smart Pie 4 and it works perfect with it.
I think it has something to do with the controller version of the earlier Smart Pie 4s
« Last Edit: July 02, 2017, 04:13:25 PM by Bikemad »
