Author Topic: Using a 750Watt Wheel with a 48Volt Battery  (Read 27133 times)
« on: February 18, 2015, 11:22:17 PM »
I have an original 750 Watt (36V) front pie. (Non-magic)
I was using Lead Acid batteries  but the weight is nuts.
I have a spare 48V LiFePO4 battery pack.
(I will need to get a second charger.)
Can I use the 36V external BAC controller with the 48V battery?
Should I get the 48V BAC and somehow limit it with software?
Thanks.
Re: Using a 750Watt Wheel with a 48Volt Battery
« Reply #1 on: February 18, 2015, 11:40:59 PM »
By default, the MagicPie or external cruise controller accepts versatile voltages from 24V to 60V. Programming a voltage is useful for low voltage cut-off to protect low battery.
Elmer, the 36V external BAC controller should work fine with the 48V battery.
