Author Topic: UK Regulations  (Read 24442 times)
UK Regulations
« on: December 19, 2014, 05:57:13 AM »
hello all,
I have a customer stating that twist throttles are illegal on ebikes in the UK. I viewed the following document and see nothing about that. Is there something else I am not aware of?
https://www.gov.uk/electric-bike-rules
Offline Hastings
Re: UK Regulations
« Reply #1 on: December 22, 2014, 07:14:52 PM »
YES
apparently it is illegal to operate a bike where power can be applied without pedaling. These bikes should be registered and undergo roadworthiness testing. However none seem to have been charged over this, nor is it possible to register bikes exceeding the statues on speed or effect as they should register a homemade bike that is let’s say 400W and then obtain a permit making it possible to obtain a valid insurance as they are exempt. Seems to be a Catch 22 moment…
http://en.wikipedia.org/wiki/Electric_bicycle_laws#United_Kingdom
Where I live in Sweden there is a similar void. And there seem to be only 4 countries that have actually made the EU directive national law.
I wonder if it is actually possible (in Sweden or the UK)for a kit builder to
Offline Wombat
Re: UK Regulations
« Reply #2 on: February 05, 2015, 05:59:09 PM »
There are a number of countries that have or are interested in taking up "EN15194" guidelines for their own e/power bike regulations albeit with perhaps a few localization tweaks.
We in "orstrayleeya" now have a majority of states that have either legislated for same or have indicated intentions to do so. The whole country was restricted to 200W but even in unlegislated states now I believe bikes tentatively legal according to EN15194 are acceptable (don't know about insurance litigation though).
The fundamentals touched on in this thread are straight forward and your UK EN15194 assumptions are applicable to most implementations...
*No PAS, NO GO; end of story.
*PAS must kick in at 6km/h>.
*PAS must shut down the motor around (legislated specifically) 25km (of course you can still pedal faster than that)... PAS should degrade towards that speed.
*Technically twist / thumb throttles are allowed but must be programmatically deactivated above 6km/h. This allows one to start moving from stationary via throttle ie safely from traffic lights etc.
*If a thumb / twist throttle when turned aggressively (ie high) does override PAS the bike is illegal (with exception of 0-6km/h). So that's all a savvy copper has to do to test it.
If there is a button or other mechanism (ie display option) that can override PAS the bike is illegal (ie if the rider can override PAS just as one could with an GM overriding throttle).
So until GoldenMotor uses all their skills shown in the design of their current e-bike products apply the above EN15194 requirements programmatically into their controllers they will become further and further behind other manufacturers regarding global certification and saleability... note its easy to build an illegal e-bike but becoming harder to RESELL them.
Untested as far as I know, it is fair to assume that if off-bike programming of a controller to swap between PAS / non-PAS modes is possible this would not constitute a breach. So if the PAS on / off were accessed only via the USB port this would be a good feature retaining all the current you-beaut GM features.
*Most EN15194 implementations mean the cruise control button is illegal. As above option should only be available in non EN15194 USB profile.
One area of inconsistency between country jurisdictions seems to be in the interpretation of or acceptance of constant / maximum output limits, if they are both applicable, and how they are arrived at (ie their may be a 15%, perhaps, allowance for the difference between constant output and intermittent maximum output limits). This at least sensibly eases the futility of a need to try and lawfully match an output limit exactly.
Always there is a vocal multitude who, with a lack of intelligence I might add, brag to all that if this and if that then they can trick the coppers. Well slowly various forces around the world are becoming more savvy about how to detect a probable e/power bike law breaker.
Basically if you ALWAYS APPEAR to be pedaling on level or rising gradients or when taking off from stationary then you will probably not be harassed by the cops. This in particular applies to on road / shared track speed junkies with over powered bikes - just keep on pedaling like hell even if not actually assisting very much; at least make it look like you are.
Of course in EN15194 jurisdictions a copper with nothing better to do will definitely notice a bike with one of those dirty great big magic pie motors shoved in amongst all those short spokes!
Lastly, at the end of the day it may not matter if your bike is a "little bit" illegal. What really matters are the more and more savvy police and insurance companies that put the onus on you to prove your bike is legal when an accident and perhaps injury to others or property is involved - then it can become very expensive.
Even after the incredible bad luck I have had with a GM SmartPie3 and lack of response to my last "within warranty" request for a replacement I would probably buy a new SmartPie4 if only it would include EN15194 USB setup options. But now I have had to look elsewhere for a replacement.
Offline Supchrgamx
Re: UK Regulations
« Reply #3 on: February 18, 2015, 03:48:56 PM »
so you incorporate  a switch on your handle bar to switch back and forth
you get around legislation buy having the tail light mandatory and flash when in en1594 and on solid when in off road mode and with no load to the tail light it stays in en1594
because in Canada , 95 percent of my riding is off road and I feel the power levels are still to low for that
Laurence
Offline Gregor
Re: UK Regulations
« Reply #4 on: April 11, 2015, 11:51:14 AM »
Just don't get caught.
having no practical effect or useful result is futile
Offline Supchrgamx
Re: UK Regulations
« Reply #5 on: April 18, 2015, 02:36:03 AM »
common sense goes a long way
Offline RooGM
Re: UK Regulations
« Reply #6 on: May 08, 2015, 02:00:13 PM »
When I lived in the UK a few years ago I had an e-bike with a half twist throttle.  It was not a DIY job, it came like that new and was fully legal.  If it's a new law that makes it illegal what happens to the people who bought those bikes before the new law?
