Author Topic: MP3 Ignition Switch  (Read 26528 times)
Offline jmeaghan
MP3 Ignition Switch
« on: December 19, 2014, 01:45:16 AM »
Hello I would like to add an ignition switch to my ebike as I have to continually unplug/replug it currently.  Would anyone be able to recommend one?  I have a MP3 48V system.
Cheers
Re: MP III Ignition Switch
« Reply #1 on: December 19, 2014, 06:08:02 AM »
I have these...
http://www.goldenmotor.ca/products/Keyswitch.html
They are the ones that come with some of our aluminum cased  batteries.
Offline jmeaghan
« Reply #2 on: December 30, 2014, 09:50:33 PM »
Hello Gary,
Do you have a wiring diagram for the switch as I would like to buy one.
Thank you.
« Reply #3 on: December 31, 2014, 04:21:41 PM »
The switch is very easy to wire up as it only has a single pair of contacts which are used to make the connection on the positive lead between the battery and the controller as shown here:
« Last Edit: July 05, 2017, 04:08:27 PM by Bikemad »
Offline jmeaghan
« Reply #4 on: February 11, 2015, 05:46:53 AM »
Hello Alan sorry for the delayed response. Looking at the picture this appears to be a high voltage ignition switch for 48V.  Is that correct?  If so is this the one sold on the Goldenmotor website?
Thank you.
« Reply #5 on: February 11, 2015, 11:13:59 AM »
You're right Jeremy, it's the main battery power switch that is used on GM's 24V, 36V and 48V rack mounted batteries and Gary usually keeps these in stock:
You may have noticed that it also has a key activated locking pin that keeps the battery in place, but I don't suppose you are likely to use the battery locking function.
Offline Craglett
« Reply #6 on: December 07, 2015, 07:58:48 AM »
Hi everyone.
I appreciate this thread has been inactive for a while but I'm looking for a UK supplier of this keyswitch for my 48v battery. I have found it on the Canadian website but it's very expensive to post.
Can anyone point me in the right direction?
Craig
