Author Topic: BAC-0281P external controller.  (Read 33199 times)
Offline trike
« on: December 02, 2014, 08:27:15 PM »
Should I run my BAC-0281P External Controller out in the open somewhere or can I run it in a bag.
Re: BAC-0281P external controller.
« Reply #1 on: December 05, 2014, 11:54:28 AM »
Keeping the controller cool is very important, especially if you are using high current settings and lots of throttle.
Ideally, the controller should be mounted where the airflow can easily pass over the cooling fins to provide optimal cooling.
It should be possible to fit the controller inside a box or bag to allow the wiring and connectors to remain clean and dry, but leave the cooling fins exposed like Phil did:
Take a look at this post for a similar suggestions.
« Last Edit: July 13, 2023, 10:53:18 AM by Bikemad »
Offline Hastings
« Reply #2 on: December 06, 2014, 05:23:17 PM »
 Hi   Have a look at my solution: ie an external cooler for a built in controller best of two worlds
http://goldenmotor.com/SMF/index.php?topic=5010.msg29172#msg29072
« Last Edit: July 13, 2023, 10:47:36 AM by Bikemad »
