Author Topic: How to stop rain problems in MP3??  (Read 22184 times)
Offline Quiro
« on: September 26, 2014, 07:49:05 PM »
Hi Forum,
I found in the forum some issues with raining weather and MP3, specially controller and I am quiet worry about that problem because I can not leave my bike under roof and her in can rain a lot . So I wondering if I seal the controller from out side (seal all the self cooling fan) should solve the problem??
Could I get other problem because I close the self cooling fan?? I Never read a problem of motor getting to warm... and the Mp2 did not have this self cooling fan.
Thanks for information and help...
Quiro
Offline Sam.Vanratt
Re: How to stop rain problems in MP3??
« Reply #1 on: October 13, 2014, 02:50:22 PM »
Hi Quiro
the MP3 is sealed by default on all metal connections, BUT the screws and the cable is not water resistent. So the cable needs to have a U turn (so all water pouring down drops on the U-turn down and not into the cable=> controller. As I had to change my MP3 controllers (I have two running) one time I did use simple silicon glue after reassembling.
Despite your reading I heard a lot of Overheating problems, mostly due to "full-throttle" configs (48V+ Batteries, 30A+ config) which get's the max out, but exaggerates the waste heat. When it's hot as well the controller surely died a few times under these overdrive conditions.
In my worst case (EU regulation) I have a 24V/12A config and never even felt the controller nor the motor itself getting warm at all.
Cheers
Sa,m
