Author Topic: how to use pedelec function about the cruise controller  (Read 25807 times)
Offline TOM
« on: February 18, 2009, 08:05:16 AM »
Short your C&Z twice,hear a beep,means this pedelec function has been opened and can use this pedelec.
Offline wepbep
Re: how to use pedelec function about the cruise controller
« Reply #1 on: March 05, 2009, 12:12:38 PM »
Is this for all controllers ? Does it mean that by default the pedelec function doesn't work ?
Offline b-twinelec
« Reply #2 on: April 30, 2009, 09:33:11 PM »
Hello,
Just received a kit 24 V with MX 24C EB D controller with PAS Pedelec sensor. I was not able to have the sensor working up to the moment I found on the forum this post saying that you need to short twice the C & Z wire to have the sensor activated. I did that quickly... and it works. However, what if I want to use this controller without cruise control switches?
Each time I restart the kit, it seems I need to redo the same procedure to have the PAS sensor working again. Is there away to avoid this and stay in the pedelec mode all the time?
Thanks for your help.
« Last Edit: May 01, 2009, 08:28:53 PM by b-twinelec »
