Author Topic: MP3 CONTROLLER  (Read 21747 times)
Offline Supchrgamx
MP3 CONTROLLER
« on: May 10, 2014, 03:05:27 AM »
Im running 48v 15 ah and the bms has a 30 amp shut off
the software control seems to not work ,when I turn it to 20amp peak and run, it stills pulls to 30 amps
is this normal
Laurence
Offline Supchrgamx
Re: MP III CONTROLLER
« Reply #1 on: May 10, 2014, 04:22:18 AM »
windows 7 64 bit
connect successful
get config doesn't work
disc doesn't work
« Last Edit: May 10, 2014, 04:24:19 AM by Supchrgamx »
Offline Supchrgamx
« Reply #2 on: May 11, 2014, 10:31:24 PM »
seems like the driver software for the usb cable is for 32 bit machines
any 64 bit drivers on the horizon?
otherwise the bike is awesome
Laurence
Offline Supchrgamx
« Reply #3 on: May 14, 2014, 05:31:40 AM »
ok I don't know what im talking about,just tried vista 32 bit. same thing, I give up, liening towards some thing died. maybe im being to rough on it. after all ,I did get a trip to the hospital for a cat scan because I was having way to much fun and then walked funny, for six months.
Offline Supchrgamx
« Reply #4 on: May 17, 2014, 02:12:35 AM »
I guess when it says its connected, that means that it is only connected to the ic in the usb cable and not nessasarly connected to the controller. on further inspection I found some chaffed wires going to the future display jack. after moving them around abit ,access was granted to the controller.so far I like what I see and on a side note the usb feeds the controller with 5 volts and it is switched on and off by the ic in the usb cable, so it(5v) appeared after successful connection
