Author Topic: Magic Pie III Regenerative Braking on Throttle PROBLEM  (Read 23247 times)
Offline k__x
« on: April 19, 2014, 10:25:03 AM »
Hi!
i don't know whats happenig, I have a Magic Pie III and, sometimes, im having Regenerative Braking on Throttle!!!  :o
but the regenerative braking is OFF,  0%, programed in USB /PC, and it should not do Regenerative Braking on Throttle  :-[
for example,
im with 100% Throttle at 30 km/h, then I low the Throttle from 100% to 10% and it start doing soft Regenerative Braking (example (+-)   - 30W  in Cycle Analyst)...
if I low the Throttle from 10% to 5%, it makes a big Regenerative Braking (example (+-) -160W  in Cycle Analyst),.... if I low the Throttle more, it makes even more regenerative brake until the wheel stops...
but if I disconnect the batterys and connect it again, it stops doing that...and get normal....
sometimes it do it, sometimes it dont.... :'(
what can I be?
« Last Edit: April 19, 2014, 10:32:29 AM by k__x »
