Author Topic: Smart Pie - Disc Brake  (Read 24024 times)
Offline SG
« on: March 04, 2014, 09:45:04 PM »
Hello,
I have a 12" rear wheel Smart Pie and was wondering if the 140mm disc brake is compatible with it?
http://www.goldenmotor.ca/products/140-mm-Brake-Disk.html
Thanks,
SG
Re: Smart Pie - Disc Brake
« Reply #1 on: March 05, 2014, 02:49:29 PM »
I would expect the holes in the GM disc to be correct for the threaded holes in the motor, therefore it should be compatible, but hopefully someone who has actually tried it will confirm it.
Offline Dan77062
« Reply #2 on: November 02, 2014, 09:49:36 PM »
Did you get an answer to this?  I have the same question.
