Author Topic: Blown components on controller  (Read 25208 times)
Offline Yochanan
« on: December 17, 2013, 10:45:27 AM »
My engine stopped working
LEDs work well. But when I click on the Speed ??Throttle nothing happens.
I opened the controller. There are two components burned (pictured below) in red
Anyone know what the values ??of these components?
Currently according to tests done on the intensity of the main wires. There is a problem at +5 V
Have some sort of diagram of the controller can see there how everything is connected?
Thank you.
Offline Eriknoort
Re: Blown components on controller
« Reply #1 on: December 17, 2013, 11:04:09 AM »
The capacitor is 47uF 10V
The Resistor is 2K
Offline Yochanan
« Reply #2 on: December 17, 2013, 12:56:45 PM »
thank you eriknoort
i replace the capacitor and the Resistor
but the same problem. the LEDs are on but the motor not working
stil the white wire thet supposed to be +5V is on 0V (on this layout)
any suggestions?
Offline Nimschoe
« Reply #3 on: December 17, 2013, 04:18:15 PM »
Hi, I have the same issue as several mentioned in that thread:
The programmer.exe did actually beep and show "load successfull"( or similar) on the screen but stopped doing this after I played with the settings a bit for no known reason. Right now I have no clue if the program actually connects to the controller and if it changes any setttings or not. Worst of all: The motor is not doing anything anymore, LEDs show a filled battery, but pushing the throttle does, ehm, nothing, no effect, no movement :/
I allready tried reinstalling the programmer, run it in admin-mode, I even lighted a candle and danced around my altar to rythmic music, but no success so far -.-
And: A friend of mine is relying on me getting this thing to work properly so I d like to "somehow make it work" asap.
Halp, pls!
