Author Topic: Motors still go with brakes applied.  (Read 21127 times)
Offline Lazyrider
« on: November 25, 2013, 03:10:23 PM »
On the duel mp3 both motors still go with the brakes applied.
Connectors 1 and 4 and both definitely plugged into the harness.
It has been like this since I got it.
Offline Lazyrider
Re: Motors still go with brakes applied.
« Reply #1 on: November 26, 2013, 05:29:59 AM »
Cruise control also works but doesn't disengage when the brakes are applied.
I've only had the bike for a couple of weeks and it was like this when it arrived.
« Reply #2 on: November 26, 2013, 02:12:18 PM »
It sounds like there is a fault in the wiring somewhere between the four way multi connector and where the harness splits to the front and rear motors.
The brake switches are supposed to ground out the brake signal wire from both controllers to cut the power during braking (and also to disengage the cruise control if activated).
