Author Topic: My lifepo4 16 cell 48v battery doesn't get charged  (Read 23106 times)
Offline Avantgarder
« on: September 07, 2013, 05:45:56 PM »
Hi All,
2 years ago I bought from GM the lifepo4 16 cell 48v battery that looks like this one:
http://goldenmotor.com/SMF/index.php?topic=4260.0
It served me for 2 years running for about 16,000km.
Power, efficiency and charging speed are as good as when the battery was new.
Starting from about a month ago I'm experiencing the following problem:
1. I measure 58v on the charger output and 52v on the battery charging input (so far so good).
2. When I connect the charger nothing happens and charger does not charge.
3. I apply a little load on the battery and the charger starts charging.
4. Now I can remove the load and battery is charged till it's full.
Starting from today steps 3-4 do not help and battery does not charge whatsoever.
I do not have a spare charger to verify that the charger is OK.
Questions:
1. Does the behavior described here fit an aging battery ?
2. Does the fact that the performance of the battery is still good after 2 years indicate a good battery ?
3. How can I overcome this charging problem ?
Offline simplyfly
Re: My lifepo4 16 cell 48v battery doesn't get charged
« Reply #1 on: September 08, 2013, 12:44:11 PM »
I think your BMS is out of whack....
Offline Avantgarder
« Reply #2 on: September 08, 2013, 01:48:45 PM »
New fact that might shed some light :
I found out why yesterday I wasn't able to charge the battery with the trick of applying load on the battery:
Yesterday, for the first time in a while I tried to charge the battery when it was 50% full.
After it was completely empty it could be charged to 100% with no problem whatsoever.
