Author Topic: Bought a new MP kit. Not working at all.  (Read 21170 times)
Offline Milhouse
« on: August 08, 2013, 10:44:02 AM »
No sounds, no lights, not any respons at all. But when I got the kit. It was some loose wires and some open connections with no cable to "put in". I have no cloue - and i'm kind of a noob at those thing. But I use the instructions and.... it's just - dead.
I made this video of my bike. Can you see what I missing, or what's wrong. And - one more thing - when I try to charge the battery. It just lights two red lights at the charger at all time. But on the charger, it's written that it supose to light yellow when the battery are taking power.
Sorry for my bad english. I'm better in Norwegian. ;) Thanks for all help !!!
http://www.youtube.com/watch?v=RaCLBXAJY9U
Re: Bought a new MP kit. Not working at all.
« Reply #1 on: August 08, 2013, 05:07:06 PM »
Not to worry.  Looks like you are missing a plug.  I am not too sure about the MP3 harness.  But I would hard wire it.  There are some great threads you should search to find which wires to connect.
Here is one.  I hope this helps.
http://goldenmotor.com/SMF/index.php?topic=4314.0
Offline Milhouse
« Reply #2 on: August 08, 2013, 05:11:57 PM »
If you watch the video at Youtube. Do you see what kind of plug I am missing? :)
Thanks for your answer!  8)
« Reply #3 on: August 08, 2013, 07:33:54 PM »
Hi Milhouse,
I watched your video a few times, and have some questions and answers.
You showed a cable end with black, red, yellow and blue wires extending from the insulation.  They should be taped back, insulated, and not allowed to touch.    I'll have to look thru my notes to see what they are for.  Horn? Lights?  can't remember.
I could not see where the red and black wires from the battery are connected to the MP wiring.  Are they actually connected somewhere?
Your video showed a cut cable end, but it was blurry and I couldn't make out wire size or color.  Where does that cable come from?
Your English is fine.  I like your smiley face.  Here is mine.
« Reply #4 on: August 11, 2013, 03:57:19 AM »
Morgen, the throttle lights are on I think.
It is hard to tell the video moves fast..  He will have to get into testing the cable voltages.
Millhouse, can you get a voltage meter and test the voltages, refer to this picture.
Test all the the plug "3" voltages between battery ground - and the other signal or + wires.  Gentle with the probes now.
« Last Edit: July 02, 2017, 03:19:29 PM by Bikemad »
