Author Topic: BAC-028 controller and horn function  (Read 22313 times)
Offline Rbarciko
« on: June 24, 2013, 06:17:02 AM »
What is the voltage output of the Horn connection (A1 and A2) of the BAC-028 controller?
I have a 48v MP III system, and the horn works when connected directly to the battery, but not when connected to the external BAC-028 controller (and the horn switch works ok , as does cruise control).
« Last Edit: June 24, 2013, 06:29:52 AM by rbarciko »
Re: BAC-028 controller and horn function
« Reply #1 on: June 24, 2013, 02:26:21 PM »
I don't know what voltage is used for the horn connections on the BAC controller, but if the external MPIIIs use the same main harness as the internal ones, the horn/light unit you have shown should connect directly to the blue, yellow, black and red wires coming from the front harness main connector shown at the top of this diagram:
I hope this helps.
« Last Edit: July 02, 2017, 03:22:24 PM by Bikemad »
