Author Topic: Car conversion, would the 10Kw motor be enough  (Read 47806 times)
Offline Tokio69
« on: May 14, 2013, 03:31:49 PM »
Hello Everyone,
I'm a new member and I'm looking arround to maybe start working with GM as a supplier.
I see that alot of buggy's and very light weighted vehicles are using this motor but how about a normal car that weighs about 800kg.
Maybe one motor wil not be enough and therefore i'm looking for some experienced guys to help me out.
Greetings
Tom
Offline OzGeeksGarage
Re: Car conversion, would the 10Kw motor be enough
« Reply #1 on: May 15, 2013, 02:16:35 AM »
You may need to supply a bit more detail, there are many options, FWD /  RWD / AWD / 2WD, retaining the gearbox / diff, ratios, Auto / Manual, desired top speed, range requirements, remember you may be adding 200-500kg of batteries too preferably not inside the passenger compartment if they are Lead Acid.
You could have one motor on each rear wheel or one on every wheel too.
« Last Edit: May 15, 2013, 02:19:11 AM by OzGeeksGarage »
Please excuse my crappy typing, I'm partially blind
Offline Tokio69
« Reply #2 on: May 15, 2013, 07:00:12 AM »
True, more details
RWD , variomatic gearbox, ratio 3.6/1 up to 14.22/1
desired speed if possible 120km/h
Batteries lifepo4 120V pack weight 130kg without case.
Car without gasoline stuff about 600kg
Range , as much as possible. Now choosing for a 100Ah batterypack for this concept car , all can go under the hood, nothing in the back.
Tom
