Author Topic: Magic Pie 3 Nuts  (Read 28317 times)
Offline jmeaghan
Magic Pie 3 Nuts
« on: May 04, 2013, 02:57:15 PM »
Hello I need to replace the nut that holds the Magic Pie 3 wheel on my bike frame.  I am having difficulty locating the nut as it appears to be an uncommon size.  Does anyone know what size the nut is or where I might be able to buy it?  I am going to try shops that specialize in fasteners.  Any help would be appreciated.
Thank you.
Jeremy
Offline Zero
Re: Magic Pie III Nuts
« Reply #1 on: May 04, 2013, 03:51:11 PM »
for mp2, if I remember correctly, it should be 13x1,5mm thread, dno if it is same for mp3
Offline MAGICPIE3FOCUSPOWER
« Reply #2 on: May 04, 2013, 03:54:37 PM »
m14 1.5
Offline jmeaghan
« Reply #3 on: May 04, 2013, 10:53:11 PM »
Thank you for the info.
Cheers
Jeremy
Offline jbc@jcudney.com
« Reply #4 on: May 05, 2013, 12:24:02 AM »
Try an auto supply shop - Honda/Toyota use the same size nuts on their wheels. Just put them on backwards with the tapered side out.
« Reply #5 on: May 08, 2013, 08:29:37 PM »
That's a great tip!
I have not heard that one before.
« Reply #6 on: May 09, 2013, 07:46:38 AM »
Just buy right nuts with flange it's better than car nuts (those are design for rims with some countersunk holes...).
Better be safe buy nuts with flange and some spacers....
Offline jmeaghan
« Reply #7 on: May 31, 2013, 04:58:00 PM »
Hello I have finally found some replacement nuts.  If anyone else is having trouble finding them please feel free to send me a message.
Cheers.
Jeremy
« Reply #8 on: May 31, 2013, 06:07:42 PM »
It's a common size you can also find them at scooters...
