Author Topic: MP3 For maximum speed  (Read 22234 times)
Offline nobrac1
« on: April 04, 2013, 06:26:10 PM »
I have a MP3 48V 10 A\H set up on a 26" rear wheel drive with no PAS. I was wondering what is the best configuration for the controller for max. speed. Example Rev disabled or enabled?, Brake 100%?, Amps, Watts? etc.
Thank you for your help.
Re: MP III For maximum speed
« Reply #1 on: April 05, 2013, 01:41:36 AM »
If you set the Maximum Continuous and Peak Current settings as high as possible (and make sure the FWD Scale Speed and Acceleration is set to 100%) and it should achieve the highest speed in the shortest time.
The REVerse and Brake settings won't make any difference to your forward speed.
