Author Topic: charging plug 48v 10ah battery  (Read 25808 times)
Offline atcspaul
    • motor bicycling
« on: March 28, 2013, 05:40:08 PM »
does anyone know what type of plug the charger to charge the golden motor batteries? it looks kinda like an rca plug.  if anyone knows the type plug it is with a model to search I would really appreciate it
Offline MAGICPIE3FOCUSPOWER
Re: charging plug 48v 10ah battery
« Reply #1 on: April 02, 2013, 06:14:15 PM »
Any pictures?
Offline atcspaul
    • motor bicycling
« Reply #2 on: April 02, 2013, 07:38:18 PM »
i been told they are regular rca plugs. here is picture
« Reply #3 on: April 02, 2013, 08:27:30 PM »
Yup I think you are right looks RCA to me.
Maybe you have some RCA cables laying around and compare?
Offline atcspaul
    • motor bicycling
« Reply #4 on: April 02, 2013, 09:38:20 PM »
i tried and they seem to fit however a regular male rca jack the center or positive sticks way out thier. still doing some searching and will let you all know what I come up with
Offline Wadda
« Reply #5 on: April 03, 2013, 08:57:21 AM »
To me it looks like a Kobiconn conector, but without some specs the detail and perspective just lead to a lot of guessing on my part.  It doesn't help to not have one to see, touch, taste....just kidding about the taste.
When you say "seem to fit" an RCA...how close is that?
With an RCA, the male  pin is 3.175 mm in diameter; the outer contact is 8.25 mm in diameter...and, as you noted quite long.
« Last Edit: April 03, 2013, 09:08:42 AM by Wadda »
Offline atcspaul
    • motor bicycling
« Reply #6 on: April 03, 2013, 12:28:59 PM »
the rca plug will plug in with a nice fit. something tells me in my head that an rca audio plug is not what I should use though
Offline Wadda
« Reply #7 on: April 04, 2013, 08:16:44 AM »
RCA plugs/jacks can be (and are) used in power circuits.  I tend to think of them as audio connectors because that's what I'm used to....
Approaching it from a theoretical angle what you are doing is joining two circuits.  You can do this with a single wire; two wires that have been soldered; two wires mechanically joined by crimping/twisting...held together with a wire nut, vinyl tape and or goop for extra protection...whatever.
A connector like an RCA is just an easy(ier) way to tie two circuits together...most often in a way that can be undone and repeated with ease and without loss of material and too much time.
To make an obvious statement; Any method will work if it does what it's suppose to do.
1) Is it 'easy'?
2) Cost effective in time and material?
3) Able to transfer the "stuff" ( current, voltage, data, frequency, etc.) without getting in the way?
4) Sufficiently secure from interruption from the environment...anything from intermittent shorts, corrosion, gravity, or unintentional 'mishaps'
5) Whatever design criteria someone needs/wants...
If an RCA plug is not sloppy; makes a solid connection; does not have significant internal resistance; and you're not bothered by the positive making contact before the negative...what's the issue other than "It's an audio connector"?
Offline atcspaul
    • motor bicycling
« Reply #8 on: April 07, 2013, 11:05:25 PM »
i ended up getting a solder rca plug. works great and they have them at radio shack. here is a picture of the female which I put on my new battery
