Author Topic: Hall Sensor - how to choose?  (Read 35816 times)
Offline Just
« on: February 08, 2013, 06:03:35 PM »
Hi All,
How to choose hall sensors for hub motors? There are many and all of them look similar for me.
Thank you!
Offline MAGICPIE3FOCUSPOWER
Re: Hall Sensor - how to choose?
« Reply #1 on: February 08, 2013, 06:22:47 PM »
I am usinng Honeywell S41.
Offline Just
« Reply #2 on: February 08, 2013, 06:36:28 PM »
Waw! Is it different from 41FS36 one? How did you choose the the S41 one?
« Reply #3 on: February 08, 2013, 06:39:38 PM »
The price! ;D
No need for other features for hubmotor this sensor is just fine.
Also what kind of brand is 41FS36?
Offline Just
« Reply #4 on: February 08, 2013, 06:59:40 PM »
I was told it's also Honeywell
« Reply #5 on: February 08, 2013, 07:29:49 PM »
Aaha while looking for this model I can't find anything.
O well it's just the features that make differences.
Offline Just
« Reply #6 on: February 09, 2013, 05:00:46 AM »
MAGICPIE3FOCUSPOWER, could you please publish a link to the Honeywell S41 Hall Sensor, which you are using? Thank you!
Offline Just
« Reply #7 on: February 09, 2013, 05:47:20 AM »
What's the difference between OmniPolar, BiPoloar and UniPolar sensors?
« Reply #8 on: February 09, 2013, 07:54:36 AM »
You need the bipolar it's like 0 or 1 same as 5V or 0V when sensor is working.
Operate when there is positive magnetic (S) and stop working when there is negative magnetic (N).
Unipolar = just require positive magnetive (S) for operating and stop working (ofcourse in the positive magnetic field).
Omnipolar= operate when there is S or N magnetic field.
http://sensing.honeywell.com/honeywell%20sensing%20and%20control%20product%20search?Ne=3025&N=3102
« Last Edit: February 09, 2013, 08:36:56 AM by MAGICPIE3FOCUSPOWER »
Offline Just
« Reply #9 on: February 09, 2013, 11:03:48 AM »
All Hall Sensors in my Motor provide 5V - no matter of the wheel position. Should I consider that all of them are failed?
Here is how I did the test:
1) disconnected the Motor from anything
2) connected 5V supply to the thin RED and BLACK wires coming from the motor (thick wires are phase wires, thin ones are sensors)
3) connected a Pull-Up 10K register to one of the thin sensor wires coming from the motor
4) connected a multimeter between the BLACK (GND) wire and the output of one of the sensors (there are three - GREEN, YELLOW, BLUE wires)
5) slowly rotated the motor forward and then backward - the multimeter shown 4.9V all the time without any relation to the motor's position
I repeated stares 3-5 for each sensor and got the same results...
Have my sensors failed?
Thank you!
« Reply #10 on: February 09, 2013, 11:26:03 AM »
What is Pull-Up 10K register
Maybe you can try this: measuring between red wire end the sensors wire and whithout the Pull-Up 10K register.
Offline Just
« Reply #11 on: February 09, 2013, 11:40:28 AM »
Some of Hall Sensors have open-drain outputs - so they need either a load or external Pull-Up resistor in order to provide the correct voltage levels. Without this Pull-Up register all the sensors provide 0V without any relation to the motor position.
Could you please provide the whole part number of the sensors, which you use (you only wrote you use 'S41' sensors, but this is just a part of the whole part name).
There are sensors with low-, medium- and high- Gauss - which one would you prefer? What's the difference?
Do a wheel size effect on the hall sensors choice? Actually I need sensors for 12" geared hub motor.
Thank you!
« Reply #12 on: February 09, 2013, 11:47:46 AM »
Offline Just
« Reply #13 on: February 09, 2013, 12:09:56 PM »
Your Hall Sensor also requires an external Pull-Up register - you could see an installation diagram in the provided by you doc.
« Reply #14 on: February 09, 2013, 01:06:48 PM »
Nope I have just tested without any pull up resistor(s).
I have just measured between red and hall sensors output.
And their outputs are fine (5V or 0V).
