Author Topic: I am pulling 3KW peak...no problem for MP3  (Read 43525 times)
Offline MAGICPIE3FOCUSPOWER
« on: January 11, 2013, 08:47:39 PM »
Well,
Waauww I am impressed I can pull 3KW peak when starting.
Motor has run 100km now, I hope it will last long.... ;D
The peak current is 72A my controller will cuttoff.... ;D
And normal flat road it will use 10A so that is about 500W at max speed 40 km/h :)
A lot of torque, I can still feel it after the crash (wheelie when starting up).
Offline Lollandster
  • Norway
Re: I am pulling 3KW peak...no problem for MP3
« Reply #1 on: January 14, 2013, 09:31:44 AM »
What did you do? Only playing with the internal controller or have you got an external installed?
I managed to get my SmartPie to do 3kw too  ;D But I was pushing 80 volts at it.
Disclaimer: I know nothing.
My ebike Build blog
« Reply #2 on: January 14, 2013, 08:00:40 PM »
Nope after the internal broke and got a new one.
I have no more faith in this controller.
So I went for Kelly.... 8)
Waauww much better.
Haha 80V wauuww, I am using only 48V ;D
« Reply #3 on: January 17, 2013, 08:03:34 PM »
Okay after 300 km running time.
There is a knocking noise coiming out the motor, I suspect it is the big bearing problem >:(
Offline Lollandster
  • Norway
« Reply #4 on: January 17, 2013, 08:05:25 PM »
I looked inside one of those MPIII yesterday and the big bearing on that one is much bigger than on the SmartPie. Good luck on repair.
My ebike Build blog
« Reply #5 on: January 17, 2013, 08:08:50 PM »
Yup is really a big bearing......
I have to order some from Ebay (China).
I can't find real quality one:-(
Offline Lollandster
  • Norway
« Reply #6 on: January 17, 2013, 08:30:35 PM »
I bought from a seller called Asia Engineer. It isn't top quality, but unlike all the other china sellers I found he at least mentioned some numbers (like V1 vibration, ABEC1 and 8000rpm).
My ebike Build blog
« Reply #7 on: January 17, 2013, 08:33:00 PM »
Yes I would to buy at least ABEC 3 or higher.
ABEC 1 is crappy........
Offline Lollandster
  • Norway
« Reply #8 on: January 17, 2013, 08:37:11 PM »
I ordered ABEC3 for the small bearing and that small bearing cost as much as the big one so I'm guessing a big ABEC3 bearing is going to be very expensive. What's the number on the bearing?
My ebike Build blog
« Reply #9 on: January 17, 2013, 08:39:13 PM »
I would like to have: 6917-2RS
Yes maybe it's expensive, but better then destroying the motor......
Offline Lollandster
  • Norway
« Reply #10 on: January 17, 2013, 08:56:44 PM »
wow, that one is like 3 times as expensive than the 6812 I have in my SmartPie. If you read the thread about the SmartPie bearing you'll know I was quoted $200 for my SmartPie bearing at my local dealer, a new SmartPie without controller and rim is $128...
My ebike Build blog
« Reply #11 on: January 17, 2013, 09:04:39 PM »
Did you found one?
Yes I am worry now maybe it was a bad idea to sold my HS3540 motor... >:(
Offline Lollandster
  • Norway
« Reply #12 on: January 17, 2013, 09:15:37 PM »
No, but I just briefly checked the sites I used when ordering mine. All I found where ABEC1.
My ebike Build blog
« Reply #13 on: January 17, 2013, 09:25:45 PM »
Thanks.
I think I just ride when it break.
Then I will buy a motor with normal bearing... :)
« Reply #14 on: January 17, 2013, 10:05:15 PM »
I am lucky...
I have found one quality bearing, but it is a open bearing.
O well I don't mind the bearing is still in the motor, so dirt etc can get in.....
Pff......I feel a little relief now...
