Author Topic: What's the BEST battery for eBike?  (Read 111954 times)
Offline Just
« on: December 30, 2012, 07:46:25 AM »
Hi All,
I have Cyclone's 1200W motor, which works from 48V battery. The continuous current is ~25A, peaks up to 50A.
I wanna to use 10Ah battery for this system.
What battery cells would you recommend? The cells should support at least up to 5C of continuous current.
Thank you!
Offline MAGICPIE3FOCUSPOWER
Re: What's the BEST battery for eBike?
« Reply #1 on: December 30, 2012, 10:38:15 AM »
Go for Headway and 50A bms 8)
Offline Just
« Reply #2 on: December 30, 2012, 11:58:30 AM »
Yes, I actually used till now the 38120S 10Ah cells from Headway... They are cylindrical, take some place and a bit heavy...
So, now I'm seeking for some good cells to replace the Headway's ones....
Offline Lollandster
  • Norway
« Reply #3 on: December 30, 2012, 12:25:19 PM »
If you don't mind burning down your house then HobbyKing Lipos should meet your demands. That is what I am going to use as my secondary battery.
Disclaimer: I know nothing.
My ebike Build blog
Offline Just
« Reply #4 on: December 30, 2012, 12:50:59 PM »
Waw! LiPo are dangerous! I would avoid them.. Are there other options?
« Reply #5 on: December 30, 2012, 03:31:10 PM »
Maybe you can look here.
http://www.ev-power.eu/
Offline Just
« Reply #6 on: December 31, 2012, 04:35:59 PM »
Have you tried to order from there? Have got? Tried?
Thank you
« Reply #7 on: December 31, 2012, 10:51:34 PM »
Nope I love Headway and I will stick to Headway.
Untill there is something better.........
I like the screw feature, I can rebuild the pack easily without soldering....
Offline Just
« Reply #8 on: December 31, 2012, 11:01:09 PM »
Cells in www.ev-power.eu are also with screws and they are rectangular (better than cylindrical ones). Not sure regarding their life cycles and internal resistance - they don't publish these vital parameters.
Why did you recommend this site?
What's the official site of the Headway batteries? I'm a bit confused regarding these batteries. There are many companies sell these cells? Is the Headway not a trademark? Is the company USA-based? China-based? Other?
« Last Edit: December 31, 2012, 11:10:08 PM by just »
« Reply #9 on: January 01, 2013, 10:22:21 AM »
Well I have bought small battery for my battery charger.
It looks much better then Chinese Ebay ones and the choices are big!
But the prices....... >:(
Also if you look at Headway specs, Headway is much better for your money :)
Headway website:
http://www.chinaheadway.com/
Offline Just
« Reply #10 on: January 01, 2013, 10:35:07 AM »
My Kaspersky AntiVirus reports on TROJANS on this site... I'd avoid to open it... If you are not, would you please let me know their email address?
Thank you!
« Reply #11 on: January 01, 2013, 11:47:23 AM »
Zhejiang Xinghai Energy Technology Co., Ltd.
Add: Taihu Road Eco & Tec Development zone Changxing County Zhejiang, China
Tel: 0086 572-6128999 ,6765968
Fax:0086 572-6128570
P.C.:313100
E-mail:market@xhnykj.com
Website:http://www.xhnykj.com
Offline Just
« Reply #12 on: January 01, 2013, 12:10:03 PM »
This site also try to inject Trojans to the visitor's PCs. But thank you for the email address! Trying to ask them some questions...
« Reply #13 on: January 02, 2013, 02:57:21 AM »
Well I thought I should insert a few statistics on the GM LiFePO4 batteries. Ive done some calculations. Of all the LifePO4 batteries I sold so far.
Less then 2 percent Key switch failure.
Less then 1 percent Cell failure.
Less then 1 percent BMS failure.
Without getting into exact numbers the LfePO4 48V10AH battery is the number two seller on my website and the 36v12AH battery is number Six. So I have sold a lot of them. Also I have sold quite a few 48v20AH and 48v30AH batteries.
Statistically I think the GM batteries are hard to beat. Also with the large square screw top cells, if you ever did need to repair your battery is would be very easy.
« Reply #14 on: January 02, 2013, 10:23:39 AM »
Yes I had one earlier type GM battery.
But it died very quick (within a year).
Also I like to see the specs of the battery, I like to know what I am buying....
Maybe GM should share those information.
Personal I think Headway are hard to beat.
A lot of power for good value and quality....
