Author Topic: Forward and reverse on the Smart Pies  (Read 22823 times)
« on: December 23, 2012, 11:38:57 PM »
I was contacted by a customer and asked if the Smart Pies can run in reverse full time. I know the External magic controllers can do this and the MP3 internal controllers can. Since the Smart Pies use the same wiring I assumed the answer would be yes. But I can not tell a customer yes without know for sure. So after some testing the answer is YES. By default the Smart Pie runs at 47 percent power in reverse so it does take a USB cable and configuration to set it to full speed.  Here are the results.
http://www.youtube.com/watch?v=BPxOKDIz0_A
Re: Forward and reverse on the Smart Pies
« Reply #1 on: December 24, 2012, 04:25:28 AM »
If full power in reverse rotation is needed, and one isn't afraid, two of the phase and sensor leads can be swapped...
Offline Rodmiami
« Reply #2 on: January 02, 2013, 07:13:07 PM »
The twisting of the blue and black wires together on the wiring harness of the Smart pie did the trick . I have the motor running in reverse so I can use the disk brake on my Nirve now . Here are some pictures of finished ( there never completely finished ) product . Rod
« Reply #3 on: January 02, 2013, 11:20:32 PM »
Nice bike!
When I grow up I want one of those!
