Author Topic: Connection two chargers in parallel  (Read 25660 times)
Offline Just
« on: October 03, 2012, 11:57:27 PM »
Hello All,
Is it possible to connect two chargers in parallel via Schottky diodes? Is it not dangerous?
Thank you!
Offline Just
Re: Connection two chargers in parallel
« Reply #1 on: October 06, 2012, 11:51:26 AM »
Any comments?
Offline Lollandster
  • Norway
« Reply #2 on: October 06, 2012, 12:33:22 PM »
Unless your chargers are smart I can't see the harm. If the chargers are smart though they need to see the state of charge of the batteries by looking at the battery voltage and that wouldn't be possible with two chargers, both because of the diode and that one charger would read the output of the other. But I can't see the harm as long as there is a good BMS controlling the actual charging. But I'm just guessing, if you brake anything its on you.
Disclaimer: I know nothing.
My ebike Build blog
Offline Just
« Reply #3 on: October 06, 2012, 12:50:54 PM »
"If the chargers are smart though they need to see the state of charge of the batteries by looking at the battery voltage" - they do... They also stop charging when decide that the battery is fully charged...
"... that wouldn't be possible with two chargers ... one charger would read the output of the other" - hm... I did not thought about it previously...  Is there any solution for this issue?
"I can't see the harm as long as there is a good BMS controlling the actual charging" - what role does the BMS plays in the charging process besides monitoring and balance the cells? Should it disconnect the Charger's current once it decides that all the cells are fully charged?
Offline Lollandster
  • Norway
« Reply #4 on: October 06, 2012, 06:37:19 PM »
Input form someone more experienced with this would be better. But as far as I know the BMS does the job of stopping the charging, if this isn't the case then two paralleled chargers wont work. I believe that the light on the charger that tells you it's finished is based on the current flowing out of the charger and not the voltage read from the battery. When the BMS stops the charging the current stops flowing and the light turns green.
My ebike Build blog
Offline MAGICPIE3FOCUSPOWER
« Reply #5 on: October 06, 2012, 06:47:08 PM »
Why would you connection two chargers parallel?
For more current?
If so I don't that will work, because those chargers are intelligent.
So current and voltage will be never the same at the outputs.
Also you can't hook up battery with bms to those chargers.
This because the chargers have their own bms.
Offline Just
« Reply #6 on: October 06, 2012, 06:58:28 PM »
Thank you lollandster, a good idea!
MAGICPIE3FOCUSPOWER: "Why would you connection two chargers parallel? For more current?" - yes, sometimes only a short period of time on the road is available.
"those chargers are intelligent. So current and voltage will be never the same at the outputs" - it's not necessary, each charger will supply as much current as it can...
"chargers have their own bms" - hmm... My charger has only two power leads and it's without a balance port... So, how does its BMS work and why needed?
« Reply #7 on: October 06, 2012, 07:02:46 PM »
BMS is needed because the offered chargers (power supply) don't have bms.
And your charger has internal power supply and bms (balancer).
