Author Topic: Battery Management System -> how to test its functionality?  (Read 23526 times)
Offline Just
« on: September 21, 2012, 12:28:20 PM »
Hello All,
I found several LiFePo4 cells in my battery pack, which was discharged to 0V. Should it be a BMS malfunction or cell problem? How to test?
When then I charged the discharged cells with a small current (about 0.1V), they were recovered from 0V to their nominal 3.3V.
Is it possible that BMS shorts the cells during a discharge?
Thank you!
« Last Edit: September 21, 2012, 10:03:49 PM by dmitryl »
Offline Kirk
  • Its not bragging, if you can do it.
    • Cape Foulweather
Re: Battery Management System -> how to test its functionality?
« Reply #1 on: September 21, 2012, 02:59:39 PM »
Its a BMS problem. Do you have a Cycle Analyst or a Watts Up meter?
I WILL NOT BE RESPONSIBLE FOR DAMAGE TO EQUIPMENT, YOUR EGO, COUNTY  WIDE POWER OUTAGES, BLOWN PARTS, SPONTANEOUSLY GENERATED MINI (OR LARGER) BLACK HOLES, PLANETARY DISRUPTIONS, OR PERSONAL  INJURY THAT MAY RESULT FROM THE USE OF ANYTHING I FIX OR SAY.
Offline Just
« Reply #2 on: September 21, 2012, 05:52:06 PM »
I have a Watts Up meter. ? So, how to test the BMS?
« Last Edit: September 21, 2012, 10:01:29 PM by dmitryl »
