Author Topic: [DIY] How to simulate a motor behavior?  (Read 33205 times)
Offline Just
« on: September 17, 2012, 06:51:33 PM »
Hello All,
How to simulate a motor behavior from point of view of current consumption? Is there a way to build a power rheostat, which would dissipate 500W-1000W (the same amount of power as a motor consumes)?
Thank you!
Re: [DIY] How to simulate a motor behavior?
« Reply #1 on: September 18, 2012, 02:55:37 AM »
Dmitryl, do you mean a load connected directly to the battery, or a load being supplied by the controller?
It should be possible to use a 3kW electric fire to load the battery directly, the current will vary according to the ratio between the fire's voltage and the battery's voltage.
3kW/240V = 12.5 Amps
240V/12.5A = 19.2 Ohms
48V x 19.2 Ohms = 2.5 Amps
48V x 2.5A = 120 Watts
So, if my theory is correct, a 240V 3kW resistive load should produce a 120W load on your 48V battery pack.
All you now need is eight electric fires (connected together in parallel) to produce a 960W load.  ???
Offline Lollandster
  • Norway
« Reply #2 on: September 18, 2012, 08:06:21 AM »
Just get yourself 10 feet of 16 AWG nichrome wire (it's about 0.26ohm per feet). That will give you P=(u*u)/R=(48v*48v)/(10ft*0.26ohm/ft)=886w. The wire will be red hot and about 700'C so try not to touch it. For less watts use longer wire and vice versa. Don't go shorter than 5 feet or you'll risk burning up the wire. If you want it cooler you'll need to use a longer wire of a lower guage (bigger cross section).
   At about $10 on ebay this would be much cheaper than buying 8 heaters. Still only resistive load though, no counter emf or any of that stuff.
edit/addon: to get desired length use the formula L=U^2/(P*R). To make it variable between 500 and 1000w you vary the length between 17.7ft and 8.9ft. Proof: L=U^2/(P*R)=48v^2/(500w*0.26ohm/ft)=17.7ft and L=U^2/(P*R)=48v^2/(1000w*0.26ohm/ft)=8.9ft. You can coil the wire to make it shorter (or buy one that is already coiled), but the heat calculation will be different.
also: do check with a multimeter that the resistance is the correct one before using it in case you got a short in you coil or the above data is incorrect. A pure resistance like this does in no way simulate a motors behavior, so unless you specify what you need the current consumption for I can't say if this will work for you. For testing a bms or a wattmeter it might work, but not for testing a motor controller.
« Last Edit: September 18, 2012, 08:36:12 AM by lollandster »
Disclaimer: I know nothing.
My ebike Build blog
Offline Just
« Reply #3 on: September 18, 2012, 05:10:12 PM »
Thank you for the formula and explanation - very useful! Now I'm also a  mathematician :)
