Author Topic: Monintoring program keeps showing the same error message!  (Read 47629 times)
murphylee
  • Guest
« on: August 19, 2012, 04:05:29 PM »
Hi, Guys!
My name is Yong and building a electric car with my team in Korea.
A couple of weeks ago, I purchased 10kw 48v BLDC motor via Ebay and a 48v 300A controller from Korean dealer.
The first problem I found was that the hall sensor connector from motor is 5pin but hall sensor connector from the controller was 6pin.
So I cut them off and just connected only wires.
and I also connected foot pedal to the controller with no connector as well.
but the program keeps showing the same message.
Current shutdown of DC contractor1 (pin3)
I am fully aware of that pin2 and pin3 are disconnected! cus I didn't connect them to anything
furthermore I used wiring diagram with no contactor.
Is contactor necessary for the controller that I'm using?
I also tried with DC Power supply but It's not in the photos.
Pls someone help me!
and the Korean dealers keep repeating all they can do is e-mailing to you ! GM!
Re: Monintoring program keeps showing the same error message!
« Reply #1 on: August 19, 2012, 05:54:43 PM »
Hi Yong,
This group can be pretty helpful, but you need to supply more information.  The specifics are very important; exact brand name and model numbers of all the components you are using, wiring diagrams you may  have received, etc.  You just haven't provided any of that.
I really like the  socks in the last photo, tho.
« Reply #2 on: August 20, 2012, 02:06:10 AM »
Take a look at this post for more information on the HPC300 controller.
murphylee
  • Guest
« Reply #3 on: August 20, 2012, 07:31:31 AM »
Let me add more photos.
These are the labels on the motor and the controller.
and definitely they were all from GM
« Last Edit: August 20, 2012, 08:40:45 AM by murphylee »
Offline SGRAND
« Reply #4 on: December 17, 2012, 04:06:36 PM »
Hello,
Did you find the solution, that she person could help you?
I also have a problem
72V battery voltage
SPEED NO LOAD 4300T/MN??????
INSTEAD OF 6000T/MN
WITH A VOLTAGE ACROSS THE ENGINE 54V?????
PROBLEM SETTING??
program HAVE YOU
THE DETAILED MANUAL
CONTROLLER?:
SPEED-  I(%)              ?
SPEED-P(%)               ?
CURRENT-I  (%)           ?
CURRENT-P(%)           ?
FWD DEGREE            ?
REV  DEGREE            ?
PAGE REVISE            ?
If you have examples of diagrams, and other thank you
cordially
M grand
