Author Topic: disc breaks  (Read 33940 times)
Offline sdalli
disc breaks
« on: January 06, 2009, 02:47:57 PM »
does anyone know if it's possible to fix disk breaks on the rear wheel motor? because I intend to buy a full disc mountain bike which doesn't have brackets for v brakes. can any one help?
10x
Offline biohazardman
Re: disc breaks
« Reply #1 on: January 06, 2009, 11:49:11 PM »
Anything is possible but some things are cost prohibitive. The motor has no place to connect the rotor.  Expect one could do some machine work to the motor plate and make an adapter of sorts to mount the rotor although it would likely be a bit of work.
Offline TOM
Re: disc breaks
« Reply #2 on: January 07, 2009, 08:48:02 AM »
Goldenmotor has this fix device.
Offline sdalli
Re: disc breaks
« Reply #3 on: January 07, 2009, 08:42:12 PM »
what fix device?
Offline sdalli
Re: disc breaks
« Reply #4 on: January 07, 2009, 08:52:40 PM »
i have the black 36V 500W rear wheel kit. are you saying that I can buy a fix device to fit the discs on the motor without any machining? I searched the golden motor website and found nothing about this.
10x
Offline TOM
Re: disc breaks
« Reply #5 on: January 09, 2009, 10:22:13 AM »
yeah
We don't sale this one now,but we use this to install our electric bicycle
Our new kit will show on the website,accessories include this one
Offline sdalli
Re: disc breaks
« Reply #6 on: January 09, 2009, 10:49:36 PM »
but I don't have any holes in the motor to screw that disc in place.
Offline TOM
Re: disc breaks
« Reply #7 on: January 10, 2009, 01:32:49 AM »
Don't need holes
HBS rear motor could be installed disc break and shift gears
HBS front motor couldn't be installed them
It only need screw thread on your covers.
Re: disc breaks
« Reply #8 on: January 13, 2009, 04:41:51 AM »
He said that the rotor is fastened to the adapter via screws and the adapter has threads that allow it to twist onto the motor. I have one for my BMC motor.
Offline gagnonjf
Re: disc breaks
« Reply #9 on: January 13, 2009, 04:37:07 PM »
No don't drills holes in your cover it's too thin. I installed disc brake on my bike no problems. You need to get a threaded disc brake adapter.
you can get it from ebikes.ca This will screw to the cover on on the rear wheel. It's the same thread as the freewheel but on the opposite side of the motor. My 1000 watt rear wheel came with that threaded cover. Then a standard ISO disc will screw onto this adapter with 6 bolts. If you don,t have the threaded cover then your out of luck or maybe it can be ordered from GM. anyway it works fine.
Offline sdalli
Re: disc breaks
« Reply #10 on: January 14, 2009, 07:31:26 PM »
i see. now I understand! too bad the case is not threaded on the left side! :( thou I think it's thick enough to drill and thread holes in it to fit the disc break! it's around 5mm thick.
Offline karma
    • http://www.karmabike.net
Re: disc breaks
« Reply #11 on: January 15, 2009, 02:09:40 AM »
hmm funny it worked for me,
http://www.youtube.com/user/karmabike1911
theres no threaded disk adapter for the goldenmotor if you want one make it :)
« Last Edit: January 15, 2009, 02:18:42 AM by karma »
Offline muzza.au
Re: disc breaks
« Reply #12 on: January 15, 2009, 07:05:46 PM »
I like the spokes that are twisted on! :o
