Author Topic: Throttle wires  (Read 22772 times)
Offline Kirk
  • Its not bragging, if you can do it.
    • Cape Foulweather
Throttle wires
« on: June 18, 2012, 08:57:02 PM »
Just going thru a bit of rewiring to a new controller and have four wires to connect to the controller. They are White, Green, Red and Black. I think the White wire is for the battery indicator and the Black is most likely ground. Which leaves the Red and Green wires for 5V and 1-4V. Memory fails me as to which one is which and I don't want to be rewiring plugs if I get it wrong. Might run out of those little pins for the plugs that way.
I WILL NOT BE RESPONSIBLE FOR DAMAGE TO EQUIPMENT, YOUR EGO, COUNTY  WIDE POWER OUTAGES, BLOWN PARTS, SPONTANEOUSLY GENERATED MINI (OR LARGER) BLACK HOLES, PLANETARY DISRUPTIONS, OR PERSONAL  INJURY THAT MAY RESULT FROM THE USE OF ANYTHING I FIX OR SAY.
