Author Topic: Re: Electric passenger Trike technical Information needed  (Read 51755 times)
Offline Praveen
« on: June 08, 2012, 07:01:02 AM »
Hi
i have planned to buy a kit of 10kW BLDC motor air cooled kit with 1:12 Gear bridge .
Can u guide me whether my selection is right for the following......
Vehicel speed I needed :Max 55kmph
Vehicle GVW : Max 1500kg
Vehicle Gradient angle : 12degree max
Any idea how much % regen energy can contribute ?
Suggestions and ideas needed......
« Reply #1 on: June 09, 2012, 01:57:07 AM »
I think you might be asking the impossible from a 10kW motor with that amount of weight and fixed gearing, which would need at least an 18" outer diameter tyre and the 8:1 gear ratio in order to reach 55kmph with the motor running at ~5,100rpm.
Now let's take a look at the following diagram:
To move a 1,500kg vehicle up a 12 degree slope you would need to exert a force of at least 312kg (1,500 x Sin 12) and that's without allowing for frictional forces at the tyres, mechanical losses through the gear-train and wind resistance etc.
I put some test figures into my spreadsheet, and discovered that the motor would need to develop at least 88Nm of torque before the vehicle would even move, let alone accelerate up the slope.
I estimate, the motor draws around 5Amps/Nm @ 120V, therefore 88Nm x 5Amps = 440Amps (52.8kW)
I estimate, the motor draws around 8.5Amps/Nm @ 72V, therefore 88Nm x 8.5Amps = 748Amps (53.8kW)
Either way, I think 53kW is probably expecting a bit too much from a 10kW motor.
In order to provide a greater gear reduction for hill climbing and a lower gear reduction for speed, I really think you would need to incorporate a manual gearbox so you could easily select the best gear ratio to suit the actual load on the motor.
« Last Edit: July 04, 2017, 10:19:06 PM by Bikemad »
Offline Praveen
« Reply #2 on: June 15, 2012, 06:07:47 AM »
Hi thanks for the reply 8).
i have noted your details.Has anyone really bought the motor with axle and ground tested practically ?
In such a case can u pls post the pin point datas with photos. ?
Regards
Praveen.
