Author Topic: Inline Resister in the Red T-2 throttle wire  (Read 22433 times)
Offline Kirk
  • Its not bragging, if you can do it.
    • Cape Foulweather
« on: May 26, 2012, 04:46:51 PM »
Anybody else have an inline resister in the T-2 throttle wire? If so what is its function. It isn't on any of the wiring diagrams from GM that I've seen. Its on a Pro 901 48V 1000W kit. I think the controller part number is BAC-0282P
I WILL NOT BE RESPONSIBLE FOR DAMAGE TO EQUIPMENT, YOUR EGO, COUNTY  WIDE POWER OUTAGES, BLOWN PARTS, SPONTANEOUSLY GENERATED MINI (OR LARGER) BLACK HOLES, PLANETARY DISRUPTIONS, OR PERSONAL  INJURY THAT MAY RESULT FROM THE USE OF ANYTHING I FIX OR SAY.
Re: Inline Resister in the Red T-2 throttle wire
« Reply #1 on: May 26, 2012, 05:16:11 PM »
That looks like a capacitor to me.  By the size and shape of it, it is probably what is called a bypass cap, used to reduce hi frequency noise from a  signal.
Offline Kirk
    • Cape Foulweather
« Reply #2 on: May 26, 2012, 07:21:37 PM »
Thanks I'll see if I can find a mate to it at Mouser or Allied and see if I can get the specs on it. The markings on it are too obscured to figure out what they are, even under a magnifying glass. Probably don't need it but it would be nice to know.
« Reply #3 on: May 26, 2012, 10:24:48 PM »
I wonder if it's a current protection device to protect the hall sensor in the throttle. ???
A similar item was fitted to the external controller wiring in this post:
« Reply #4 on: May 26, 2012, 11:34:50 PM »
After seeing how the device is wired in Alan's photo, I'm not so sure it really is a bypass cap.   The layout just doesn't look right.  The wiring is pretty large, both the same color, and at a distance from the connector.  That doesn't match a typical wiring of a bypass cap.  But having said that, the shape, color, lead layout, and marking layout are typical of a small value capacitor used for bypassing.
Can you read any of the markings?
