Author Topic: Magic pie rim cracked - Need a new one  (Read 21647 times)
Offline Avantgarder
« on: May 17, 2012, 04:42:02 PM »
My Magic pie rim started cracking in the welding spot.
Does anybody know which heavy duty rim (tandem maybe ?) is 26" , 36holes and has ERD like the stock rim so I don't have to machine new length spokes ?
Offline niceguysteve
Re: Magic Pie rim cracked - Need a new one
« Reply #1 on: May 24, 2012, 01:13:15 AM »
I'd love to know. My E-cargo tandem with ten pounds of tools,
 battery, MPie  and 180lb rider easily totals 280 lbs ....
one rim got damaged by a pothole/sewer grate so I got a new rim
and new spokes from Gary (the old ones had done a winter)
 the new rim went on very
nicely but I damaged it a few weeks later going onto a high sidewalk way to fast .
Took 90 minutes to get the back wheel off, true it with pliers and spoke wrench enough to ride home (whump,whump) and reinstall ...that's why I carry tools.
   This time I've gone the other route and the MPII is at the local high end bikestore
getting a very strong rim installed with custom spokes . The way it was explained to me is that a really good wheel builder has to calculate the spokes to the wheel and
the chances of getting a rim to fit the spokes is very slim .... I'll keep you posted.
  At present I have a new MPIII installed and the rig runs great .
 Keeping the wheel from eggshape elliptical tendencies
 due to the welding spot you speak of is a challange .
Trueing and tweaking by first loosening is working so far. To run as a two rider
tandem with a strong stoker I know that a stronger rim is needed.
Hope this is helpful ....steve
Offline Avantgarder
« Reply #2 on: May 24, 2012, 05:33:04 AM »
i emailed david from gm 2 days ago. hope he'll reply soon. I agree that buying a random tandem rim will end up in the need to machine a new set of spokes. the benefit of that though will be complete standartization of my bike. whenever i'll need a new rim , i'll know which one to buy. it's always a good thing not to be dependent on stock parts, especially when replacement ones are better...
« Last Edit: May 24, 2012, 05:35:46 AM by Avantgarder »
