Author Topic: Can the controler software Power OFF- ON  (Read 22778 times)
Offline Hastings
« on: April 23, 2012, 03:49:22 PM »
 Hi everybody
After a year of delay as I ordered the wrong size: 28 inch/635 mm MP2 when a 700c/622 was needed, Finally:
 I got my bike up and running with a Ping 48v16 AH Battery.  So far I have made a stainless battery box but not included an on -off switch as  I need one the can handle the amps if I should place it  between battery +and  the controller
 My question is if the thin red cable that is not handling the load( see the very top off the diagram) can be used for on-off signaling trough the software? and if so  do I have to activate it from a change in settings in the sofware? Right now the bicycle can be driven without this cable . It is labled off -on ....
Does any off you use a fuse and how strong ? 60 A ???
« Last Edit: April 23, 2012, 07:40:13 PM by hastings »
