Author Topic: 2 x 36V 10AH Lifepo4  (Read 41138 times)
Offline Spacelander 1946
    • Home Page
« on: December 17, 2008, 10:05:37 AM »
I have a standard 36V 10ah Lifeop4 battery.......Can I connect another(36v 10ah) to get 36V 20AH by just connecting the two - & + wires. I know I will still have to charge each battery indiviually. Cheers.....
Offline muzza.au
Re: 2 x 36V 10AH Lifepo4
« Reply #1 on: December 17, 2008, 07:08:57 PM »
Short answer - yes.
If the batteries are identical you can make it into a 36v 20ah by connecting in parallel or if the need arose a 72v 10ah by connecting in series.
Muzza.
    • Home Page
« Reply #2 on: December 17, 2008, 10:48:17 PM »
Thanks Muzza
I don't know "parallel" or "In Series" means though I'm sure my local Auto Electriction can do (I don't need 72V 10AH).....Cheers & Happy Xmas
« Reply #3 on: December 18, 2008, 12:58:29 AM »
red---------(+)-----(+)
               pack1    pack2
black-------(-)-----(-)
Parallel is where you split your lead wires so you have a red on each plus
and a black on each -, the available amps are added, so if you have two
20AH 36Volt packs, you would have 40AH at 36Volts.
red---------(+)
               pack1
                              pack2
black------------------(-)
Series is where you connect Red(+) on one pack to Black(-)
on another pack, then connect your Red(+) Lead wire to
Positive on one pack and Negative on the other pack.
This gives you the same available amps (20AH) but the
voltages are added to get 72Volts
    • Home Page
« Reply #4 on: December 18, 2008, 05:47:50 AM »
Great,now I understand....Many Thanks & Merry Xmas
Offline Echo
« Reply #5 on: December 18, 2008, 09:14:49 AM »
Thank you for your excellent reply and merry christmas!
Offline TOM
« Reply #6 on: December 19, 2008, 03:27:15 PM »
red---------(+)
               pack1
                              pack2
very good
               pack1    pack2
red---------(+)
               pack1
                              pack2
Offline Yesa-battery
« Reply #7 on: December 25, 2008, 03:00:33 AM »
yes carefull connect it
