Author Topic: put key on then battery dies  (Read 23231 times)
Offline roger j berube
« on: April 13, 2012, 09:34:54 PM »
hi my name is roger berube I have 48 v Magic Pie .i turn key on press thum throttle its dies . turn key on peddle for power its dies turn key on press crues control its dies cut wires hoock key switch up direct tries it again its still dies what should I do
Re: put key on then battery dies
« Reply #1 on: April 14, 2012, 01:54:44 AM »
Hi Roger, is this the problem you were having nearly 6 months ago that has still not been cured?
Do the LED lights on the battery gauge go off when the power cuts out?
Can you measure the battery voltage just before it cuts out?
« Reply #2 on: April 17, 2012, 08:12:18 AM »
Alan your memory is amazing!!
