Author Topic: Intermitent throttle on my pie  (Read 26918 times)
« on: December 27, 2011, 04:47:19 PM »
I pull the throttle and have power for 2 seconds. Then power cuts out and will only power again if I release throttle and re-apply and the same thing happens again.  I've resoldered throttle wires, all hall wires seem ok. Could it be a phase wire problem? :(
Andrew
Re: Intermitent throttle on my pie
« Reply #1 on: December 28, 2011, 03:04:22 PM »
Sounds more like low Voltage cut out. Does it do it with no load?
« Reply #2 on: December 28, 2011, 06:38:37 PM »
i've only tried it without load. LVC is set to 42v on a 54v pack. My Cycle Analyst is showing the battey at over 53v at present.
It maybe that I have some how mixed up the phase wires I will have to try lots of combos
Any other suggestions would be much appreciated
« Reply #3 on: December 30, 2011, 02:45:13 AM »
Looks like you have to eliminate possibilities. Try a different battery, throttle, controller, etc. Maybe swapping one item out will reveal something. I know you have an assortment of stuff. Try replacing things if possible. Im really not sure what could be doing it but thats what I would try.
« Reply #4 on: December 30, 2011, 10:25:09 AM »
Thanks Gary. I will try some differing phase wire combos first, but I do have spare throttle and controller if necessary :)
« Reply #5 on: December 31, 2011, 07:04:53 PM »
tried all 36 wire combinations and could only get a two third rotation of the wheel under throttle until cutout.
Taken pie apart today checked all hall wires which are all good.  Looks like a hall sensor failure on the motor >:(
