Author Topic: A charger for us nerds...  (Read 25989 times)
Offline Cornelius
  • Grimstad, Norway
« on: November 23, 2011, 11:39:48 AM »
My 3 year old GM 36V, 16Ah battery has been getting a bit lazy lately; I get only 25km out of one charge opposed to around 40km earlier, before the lvd cuts the power. The cell voltages are all within 0.02V of each other; both when fully charged, and after a 25km roundtrip. (Though, measured 1 week after the trip; the bms might have balanced the cells during that week of rest...)
Now, i'm very curious about most things, so I wanted to know why, so I bought an 'iCharger 1010B+':
http://www.jun-si.com/EnProductShow.asp?ID=93
Primary made for the RC market; it's also an excellent charger for us nerds that want to know more, and control more... ;D
It has support for max 10 Lithium cells, and max 10A charge current. It shows you all cell voltages, and have multiple charging schemes and discharging schemes.
3 features made me buy it: 10A charge current, it can run from a 12V car battery, and it can show you each cell's internal resistance. The last feature are what really tells you the most about a cell's condition.
With a bit fiddling, I created an adapter to fit the GM's balance plug into the iCharger, and it showed me what I suspected; all cells had an internal resistance between 15 and 25 milliOhm, except one that measured 54 milliOhm...
(When I say 'cell' here, it means one group of 4 parallel cells inside my 36V/16Ah GM battery...)
So...
Even when cell voltage showed that all cells was equal and well balanced; one cell are probably not capable to deliver its voltage under full load anymore, due to higher internal resistance. So now I know... ;D
Now; i'm working on building a replacement for my gm battery, and I will write a story on that soon. All I will say for now is that it will consist of 24 LiFePo4 cells rated at 3.3V, 10Ah each, giving me a 40V, 20Ah pack. ;)
Offline csm
Re: A charger for us nerds...
« Reply #1 on: May 12, 2012, 06:41:37 PM »
you mention it is 3 years old. I presume it is approximately 36 months old? How many charge cycles have you given it? How many miles/kilometers have you put on it at this point?
The charger seems like a good tool for battery diagnostics. Do you have a picture of your adapter? Please post. I am interested in doing the same test as you.
Also, I am concerned that you checked the cells in packs of 4. I have read reports that sometimes connections between cells can be faulty. And the possibility that there may be individual sluggish cells within the packs of 4 which may cause an overall reduction of capacity. I am fairly new at lithium pack diagnostics and am eager to learn everything I can. How much did your charger and cable adater materials/supplies cost you?
What voltage did you have your charger set to look for in your cell packs of 4, for charging and discharging??
Have you posted any videos and/or pictures of you charging/discharging/diagnostics of your packs? I would like to see them.
