Author Topic: Best motor and controller combo for fast ebike  (Read 22170 times)
Offline ic3wall
« on: October 26, 2011, 01:03:58 PM »
I just joined the forum because I have many questions to ask!
I'm currently working on building a battery pack from Li-ion cells coming from electrical tools (drills...).  My plan is to build an 26" ebike than can easily cruise at 30mph (50km/h), don't worry the battery pack will be designed consequently.  My questions are as follow:
-Is the Magic Pie II with external controller the best choice ?
-Which controller should I go with ? (something not limited too much in current I guess...)
-Is Cycle analyst the best choice for monitoring?
Setup will be mounted on a light mountain bike.
Thanks for your advice.
Re: Best motor and controller combo for fast ebike
« Reply #1 on: October 27, 2011, 12:20:43 PM »
the Magic Pie motor will make 30mph but not with the GM controller which generally restrict current to about 750w, you'll get about 22-24 mph on a 26"
cycle analyst not necessary
Check that your mountain bike drop outs(rear) are deep to hold onto the torque of a pie. My specialized Stump jumper frame has caused me many problems in this respect as it is designed for quick release spindles which don't require much depth.
Offline ic3wall
« Reply #2 on: October 27, 2011, 01:58:48 PM »
so which controller would you suggest?
