Author Topic: Fly 600 manual?  (Read 44468 times)
Offline twm
Fly 600 manual?
« on: October 11, 2011, 06:47:16 AM »
I haven't been able to find the Fly 600 manual anywhere.  I'm trying to troubleshoot my bike, which is behaving oddly (brakes don't work, and speed doesn't decrease when throttle is released).  Can anyone provide a copy of it, or a link thereto?
« Last Edit: October 11, 2011, 10:35:25 AM by spellchecker »
Re: Fly 600 manual?
« Reply #1 on: October 11, 2011, 01:27:09 PM »
Hi andto the Forum.
I'm pretty sure there isn't a manual specifically for the Fly 600, but I guess the wiring will be the same as the standard Magic Pie kits.
I'm assuming it's just the power cut-off and regenerative braking that's not working, rather than the mechanical brakes themselves.
Anyway, it sounds to me as if you may have an intermittent connection on one of the thin black ground wires, as this would definitely cause the symptoms you've described. Check all of the wiring harness and connections carefully and see if you can find any signs of damage, or loose/broken wires.
Take a look at this post for more details on the Magic Pie Wiring.
« Last Edit: July 02, 2017, 03:14:54 PM by Bikemad »
