Author Topic: Effiency comparison  (Read 21213 times)
Offline sidewinder
Effiency comparison
« on: October 04, 2011, 02:05:48 PM »
Which hub is more efficent,  a geared hub or a non-geared hub, and what are the advantages of both?
Re: Effiency comparison
« Reply #1 on: October 04, 2011, 03:17:40 PM »
Here are some helpful articles :)
Hub Motor
Direct drive mechanism
« Reply #2 on: October 04, 2011, 03:26:14 PM »
Efficiency is an ambiguous term in this usage.
Energy transfer from stored to mechanical
Is optimal when the voltage and current are
closest to equal.
Because of this you would think the optimal
case would be a  multi geared motor.
Unfortunately, introducing gears introduces
loss of energy to heat and increased weight
which costs you as well.
I believe they rate the motors in kV/rpm, but
none of the bike motors give that value.
In general higher kv/rpm motors have to
get geared down to a usable rate.
With all things considered, I choose simplicity
as the deciding factor.
