Author Topic: My charger is not working anymore?  (Read 26213 times)
Offline Serg1337
« on: September 24, 2011, 08:49:41 PM »
Hello people of the electrical motorbike world.
  Yesterday iv discovered that the charger that came with my battery is not functioning properly. I plugged it into the wall last night (not yet to the battery), and the charging light was green, when usually red. Could someone help me out with this issue?
Re: My charger is not working anymore?
« Reply #1 on: September 25, 2011, 02:33:03 AM »
Just checking, is this the charger that says something like do not connect to power without first connecting battery on the case?
Offline Serg1337
« Reply #2 on: September 27, 2011, 07:50:52 AM »
no it does not say that.
« Reply #3 on: September 27, 2011, 07:52:56 AM »
The Charger will be green until the battery is connected (or already connected) then it should change to Red once a charge load occurs.
When the battery reaches the charger output voltage (eg. 54.6v) for 48v GM battery, then the light will change from red to green indicating full charge.
Offline Serg1337
« Reply #4 on: September 29, 2011, 03:19:49 PM »
when I plug it in, it stays green! it does not switch to red.
Offline Perbear
« Reply #5 on: October 02, 2011, 08:48:33 AM »
The charger connector inside battery could be loose. Check that first.
« Reply #6 on: October 02, 2011, 04:29:36 PM »
Is it a 48V charger? If so is the red voltage switch set to 115 or 230 volts. It has to be correct to work properly.
Offline Serg1337
« Reply #7 on: October 25, 2011, 04:37:08 PM »
it is a 36V charger. I will take it apart, and take some pictures. It would be nice if I could talk to someone as I do that. If not, I will take it apart and take some pictures and see what you all have to say!
